Grosses Problem
Alt 14.09.2007, 19:50   # 1
leissi
Hi kann mir jemand helfen, bekomme seit Tagen immer wieder diese Mail:
Code:
Hi. This is the qmail-send program at mx16.ispgateway.de.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<postmaster@irgendein-server.de>:
This message is looping: it already has my Delivered-To line. (#5.4.6)
--- Below this line is a copy of the message.
Return-Path: <xxxxxxxx@web.de>
Received: (qmail 6043 invoked by uid 507); 14 Sep 2007 13:35:59 -0000
Delivered-To: postmaster@irgendein-server.de
X-Envelope-To: postmaster@irgendein-server.de
Received: (qmail 6041 invoked by uid 507); 14 Sep 2007 13:35:59 -0000
Delivered-To: yyyyyyyyyy@irgendein-server.de
X-Envelope-To: yyyyyyyyyy@irgendein-server.de
Received: (qmail 5989 invoked from network); 14 Sep 2007 13:35:59 -0000
X-Spam-Checker-Version: SpamAssassin 3.2.2 (2007-07-23) on
spamfilter11.ispgateway.de
X-Spam-Level: ********************
X-Spam-Status: No, hits=20.8 required=9999.0 tests=BAYES_60,BODY_ENHANCEMENT,
BODY_ENHANCEMENT2,FAKE_REPLY_C,FORGED_MUA_OUTLOOK,HS_INDEX_PARAM,RCVD_IN_PBL,
RDNS_DYNAMIC,STOX_REPLY_TYPE,TVD_RCVD_IP,URIBL_BLACK,URIBL_JP_SURBL,
URIBL_OB_SURBL,URIBL_SC_SURBL autolearn=disabled version=3.2.2
Received: from 204.2.218.87.dynamic.jazztel.es (HELO web.de) ([87.218.2.204])
(envelope-sender <xxxxxxxx@web.de>)
by mx16.ispgateway.de (qmail-ldap-1.03) with SMTP
for <yyyyyyyyyy@irgendein-server.de>; 14 Sep 2007 13:35:57 -0000
Message-ID: <633217459915909914.365901968337817778@web.de>
To: "yyyyyyyyyy@irgendein-server.de" <yyyyyyyyyy@irgendein-server.de>
Subject: RE:
Date: Fri, 14 Sep 2007 12:51:04 +0200
MIME-Version: 1.0
Content-Type: text/plain;
format=flowed;
charset="Windows-1251";
reply-type=original
Content-Transfer-Encoding: 7bit
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2900.3028
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.3028
Size matters even more than money, try Penis Enlarge Patch.
Habe schon Rechner auf Viren gescannt, keiner erkannt. Was ist das??
Gruss Leissi
Alt 15.09.2007, 09:42   # 2
also, was genau wundert Dich daran? Du stehst in keiner Verbindung zu irgendein-server.de? Und auch wer der Empfänger "yyyyyyyyyy@irgendein-server.de" (das ist ja die Adresse, an die nicht zugestellt werden kann) sagt Dir so gar nichts?
Heißt also, eine Spam ("Penis Enlarge Patch") wird mit Deiner Adresse ("xxxxxxxx@web.de") als Absender an eine Dir unbekannte Adresse ("yyyyyyyyyy@irgendein-server.de") geschickt. Leider gibt es diesen Empfänger nicht, darum teilt Dir als angeblichem Absender der Postmaster von "irgendein-server.de" (bzw. natürlich der Mailserver automatisch) die fehlgeschlagene Übermittung mit.
Es ist technisch kein Problem, als Absender einer E-Mail irgendeine Adresse einzutragen, darum ist von einem Problem auf Deinem Rechner nicht auszugehen.
Das sind leider inzwischen gängige Mechanismen in Sachen Spam. Nicht nur wahllose Empfänger werden mit Müll beschickt, auch der Absender wird verschleiert durch Verwendung beliebiger Adressen. Beliebig heißt hier aber nicht ungültig, da empfangende Server oft prüfen, ob es den Mail-Server des Absenders ("web.de" hier) tatsächlich gibt. Da muss Deine Mail-Adresse irgendwo abgefischt worden sein.
Ergo, Deine Mail-Adresse ist in den Fängen der Spam-Verbrecher und Du wirst solche E-Mails zukünftig häufiger kriegen. Du solltest Dich mit den Filtermöglichkeiten von freemail.web.de bekannt machen.
Grüße,
Thorsten
...bin letztens durch die Aufnahmeprüfung zur Hellseherschule gekracht! smiley crystal ball
Alt 17.09.2007, 12:00   # 3
leissi
vielen Dank für die Antwort. Mein Gedanke war da meine Mailadresse mit vorkam das Mails von meinem Rechner durch einen Virus generiert wird. Das ist ja nicht zu fassen was die sich alles einfallen lassen.
Gruss Leissi
Alle Zeitangaben in WEZ +2. Es ist jetzt 21:54 Uhr.
